Penobscot Valley 4 Wheel Drive
Please login or register.
Login with username, password and session length
Advanced search
News:
"PV4WD isn't for the mud but for the trail, the mountains, and the rocks. Mud happens though we don't look for it. We prefer any mudding to be done at the mud races."  *** Mike Reynolds ***
Author Topic: Lucifer's Jeep  (Read 274 times)
Lucifer
  • If at first you don’t succeed, call it version 1.0
  • Webmaster
  • Offline Offline
  • Model and Year: 02 TJ
  • My Jeep is not an SUV and your SUV is not a Jeep!
Lucifer's Jeep
« on: June 26, 2009, 06:11:43 PM »
Ok, so right now it's mostly stock.  I drive a 2002 Jeep Wrangler TJ.  There's a 2" spring lift on it and I'm using really worn out 31 AT's.
I put a 3300W 6KW peak modified sine wave power inverter in it a couple months ago.
Just recently I replaced both front wheel bearings and the front passenger side brake caliper along with new brake pads.
Soon I will be replacing the steering stabilizer as it has a tendency to 'hop' when I hit bumps between 40 and 65mph.  It gets bad enough at times that it shakes the muffler assembly off from the back of the cat and I'm sure folks swear I've got hydraulics that are going awry! --Not so sure it's the steering stabilizer any more.  Ran the other day with the doors off - First time in what seems like months thanks to all the rain - and had a glance at the driver's wheel while doing about 55mph.  It's wobbling bad... toe-in and toe-out... not the camber soooo now I'm thinking it's tie rods or joints?  Still haven't gotten under it since it's started raining again... Geesh!  Maybe by Christmas! LOL
Adjusted the Toe-In with Mike ZJ's help from 1.5" to 1/16th"  MUCH better!
Installed hand throttle 1.0 on 9/3/09.  Let's see if it works.  We may need to upgrade to hand throttle 1.5 or possibly 2.0.  We shal see...
« Last Edit: September 03, 2009, 12:18:35 PM by Lucifer »
Logged
May I pop your corn with my shovel?
www.pv4wd.com webmaster, profile puppeteer and Master Web-Wheeler
Page created in 0.201 seconds with 22 queries.
