Penobscot Valley 4 Wheel Drive
Please login or register.
Login with username, password and session length
Advanced search
News:
Is your screen name WHITE on the Member's Rigs page in the main site?  You haven't created a rig thread in the forum Member's Rigs section!  Do it now and message Bill so he can make your rig clickable!
Author Topic: Motor Man  (Read 275 times)
Motor Man
  • Moderator
  • Online Online
  • Model and Year: 2003 TJ
  • Daves RTI Ramp Front 1000
Motor Man
« on: September 16, 2009, 09:04:38 PM »
2003 TJ Sport
White, 92,000 miles
4 liter, 5 speed
air conditioning, cruise, tilt
Cd player
1-1/2" Motor mount lift
35x12.5x16 Creepy Crawler
ProComp steel wheels 8 x 16 Black
rugged ridge bumpers front and rear
Genright G3 6 inch fender flares
4 inch rough country lift with bent arms and shock upgrade
Rough country adjustable arms
KC lights
Napa 1,050 amp battery
Dynomax 2 1/2 inch cat back
K&N air filter
Black grill inserts
Recovery:
10,000lb Smittybilt front winch
8000lb Warn back winch
30ft 30,000lb strap
2 20 foot straps
16 foot strap
6ft tree choker
7000lb high lift jack
3 150ft cables
3ft strap
Front axle:
Dana 30
Auburn electric locker
4:11 gears
All new bearings and seals
Tereflex tube seals
Crown brake lines
1 inch wheel spacers
New rotors and brakes
Drop pitman arm
New u-bolts and yoke
Rear Axle:
2000 Ford Explorer 8.8
4:11 gears
Aussie locker
Bracket set from Knowwhere2jeep.com
Crown brake lines
Tereflex adjustable track bar
1 1/2 wheel spacers
Cast steel cover
Curry emergency brake cables
New rotors and pads
New emergency brake shoes and hardware
Sway bar delete
Transfer case:
NP 231
Rugged ridge mega short slip yoke eliminator
Tereflex 2 wheel drive low kit
Tom woods double cardan drive shaft
Gold seal greasable u joints
Tereflex transfer case shift bracket assembly
Belly up skid with only one inch drop
Chevy truck 2x2 bolt trans mount
Armor:
Oil pan and trans skid
front A-arm skids (helps protect drive shaft)
Rock slides
1/8" diamond plate Rear crusher corner guards
5" rear diamond plate flairs with 1-1/2" x .120 wall tubes
Locking gas cap cover
Tail light guards
Tail pipe, skid plate
Diamond plate cargo cover with tire mount
Tools & Equipment:
Enough tools to repair most field problems
450ftlb cordless impact wrench
Drill and bits
Spare fluids
Spare U-joints, spark plugs, belt
Safety:
Fire Extinguisher
Firstaid kit
Ambu Res-cue Mask
Tire repair kit
Electronics:
Garmin Nuvi 350 GPS
Delorme PN-40SE Earthmate GPS and topo software
Kodak dash cam
Cannon 5IS digital camera
CB
RTI ramp results:
Front- 1000
Rear- need to recheck
Future Mods:
Roof rack
Dana 60 or 70 axle
Over the knuckle steering
Differential gliders
37-12.5-16 creepy Crawler's
Internal bead locks
« Last Edit: July 16, 2010, 09:35:29 PM by Motor Man »
Logged
I'm a web wheeler.
Page created in 0.74 seconds with 22 queries.
